ArchiCAD 11 layout book freeze
Our office has just upgraded to Version 11 from Version 9. I am working on a G5, 1.6GHz PowerPC. My computer is freezing almost instantly when I try to work in the layout book. I just installed more memory to try and fix the problem and it didn't help. (I now have 1.5GB DDR SDRAM). I have worked in same file on multiple other computers in ofice and don't have the same problem. I also ran a Norton disk doctor and optimized my computer, which also was not helpful.
1 Reply 1
Make sure you have downloaded all up-dates for archi-cad. If your running from the box you must check for up-dates and follow the instructions.
To do this go to help in the menu bar, then check for up-dates.
You will find both Archicad and library updates. I highly recommend to
place these on your server for all to up-date.
Good Luck
Saul
