Installation & update
ArchiCAD doesn't like OneDrive
Dontknow
When I try to open a file or insert an item from OneDrive ArchiCAD shuts down immediately.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
6 REPLIES 6
Katalin Borszeki
Hi all,
Unfortunately we did not get an answer from Dontknow, so we could not start the investigation in this case.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Dontknow
Oeps, sorry. It's been a while since I've logged in.
Going to respond.
ArchiCAD 25.
I think software applications need to be specifically programmed to work with cloud file storage solutions like DropBox, Box or Onedrive. That could be the reason why this is not working.
Katalin Borszeki
Hi All,
We contacted Dontknow about the issue and based on the information that he provided, our developers said that this issue has no connection to AC. It is probably a OneDrive/Windows issue.
Please check the reference below: http://www.tenforums.com/software-apps/22467-onedrive-desktop-app-crashing-windows-10-a.html
Unfortunately we could not confirm this with Dontknow
Katalin Borszeki
GRAPHISOFT
Dontknow
Can't confirm it.
Problem still excists
ArchiCAD 25.
Katalin Borszeki
Hi All,
We have talked to Dontknow and apparently all of his/her CAD software (ARCHICAD and AutoCAD) is crashing when trying to open a file from OneDrive so it is probably a Microsoft related problem.
Katalin Borszeki
GRAPHISOFT
