ArchiCad running slow since iTunes update
Since iTunes was updated earlier this month, ArchiCad has been running slow (particularly when you select a library object from the toolbar). Apple discussion forums indicate I am not the only one with this problem.
Has anyone found a workaround?
I'm running ArchiCad 9 (2172 Int Full) on a G5 Dual 2G PowerMac (system 10.3.9)
16 Replies 16
To answer a few of your posts (and thanks for your interest) - The problem is evident on a G5 running 10.3.9 (my other computer running on 10.4.4 is running fine). Looking at other computers, The problem appears to be localised to 10.3.9.
I run Disk Utility once a week (and more frequently if updating software). TechTool Pro 4 is also used regularly.
The iTunes/disk utility issue is remedied by following the info in the Apple Forum announcement
(http://discussions.apple.com/message.jspa?messageID=1505537#1505537)
With regard to other posts about this potential issue I came across 2 posts on the Apple Forum whilst searching for assistance with the Disk Utility problem. I have retraced my steps and see they were both posted by the same person "Mollymae":
http://discussions.apple.com/thread.jspa?messageID=1546016&#1546016
http://discussions.apple.com/thread.jspa?messageID=1546475&#1546475
I hope this clarifies the matter.
The question still remains why ArchiCad is running slow? - but if there are only a few of us with the problem it may be a hard one to track down.
Out of interest, I would like to know how archiben opens more than 1 ArchCad session at the same time? Doesn't it automatically close each solo project when you try to open another?
TomWaltz
If you duplicate the "Archicad" executable, you can run as many sessions as you make duplicates.... as long as your machine can handle it.
Tom Waltz
Simple but effective technique! - thanks
Eduardo Rolon
Or if you use Quicksilver you can use the "Launch Another Copy" option without having to make multiple copies of AC.
see
archicad-talk.graphisoft.com/viewtopic.php?t=5297&start=0&postdays=0&postorder=asc&highlight=quicksi...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
TomWaltz
I'm not sure the solution for a person already having system problems is to install more questionable software.
Tom Waltz
Eduardo Rolon
It was just a suggestion...
Anyway if he makes multiple copies of the AC executable he has to take in consideration those copies when he runs an updater (erase and duplicate again) so that everything works fine.
AC29 US/INT -> AC08
__archiben
yep. that's what i'm doing. i usually only run two concurrent sessions, but yesterday was a special case . . . throw BGarchiCAD in there too and i actually had 5 on the go!
glad you've got your problem nailed jeff!
cheers
~/archiben
b e n _ f r o s t
