Archicad 20 extremely slow in 2d
Can someone shed light on why Archicad would be so slow in 2d drafting. everything is lagging . Have to click several times to select objects. moving and panning very slow. I'd appreciate any feed back.
Archicad 20 lates build, MacOS x Sierra, MacBook pro 2016
13 Replies 13
Podolsky wrote:
I've found the solution to this issue. Turn on hardware acceleration for 2D. And turn off background updating. Both settings you can find in Work Environment.
I am very happy, this was driving me crazy and doing this fixed everything. Thank you.
alemanda
I'm facing slowdown with AC 21 but the latest suggestions didn't change my life, unfortunately.
AC 12 was really a BEAST, Superfast!
All my troubles in speed started with AC 15, I think after they introduced transparency in the selection but I cannot say it was the cause of the slowdown even though most of the lost speed was in the selection of items ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Erwin Edel
For over a year I've been happily working in ArchiCAD20, without any noticeable delays in 2D or 3D.
Recently I've started having problems with the 3D preview 'thumbnails' (objects, windows, doors, favourites) where they generate really slow (like a few seconds). This is mostly annoying when picking a favourite from a long list waiting for the thumbs to generate.
I've been in touch with reseller and sent some diagnostic files to Graphisoft, they are looking into it.
But until recently, I would have said ArchiCAD20 is very solid on windows 10 and my workstation is a good 5+ years old at this point.
The update cycle from 18 to 19 to 20 has been painless too, so I have no old projects that I am currently running on anything else than 20.
Still haven't dived into 21 yet.
Looking back: ArchiCAD15 was damn solid, but 16 too after it received some updates and 16 gives you morphs, which in terms of modelling tools brings you close to what we have today.
17 gave me no issues either, which would mean that at least they're working with building materials.
18 means you have cinerender and also is very easy to upgrade to 20, if you would want to.
Going to 21 means dealing with no stairmaker, so personally I would not migrate a running project, since 20 is pretty solid (at least until recently for me).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
ok guys,
had same problems. tried all written above, nothing helped
but then i tried THIS:
https://helpcenter.graphisoft.com/troubleshooting/setup/preferences-cleaning/
and miraculously is helped!
hope you will be as lucky as i am
