Archicad 23 not showing anything
My Archicad 23 is not showing anything that i draw in 2D and also 3D
My system:
OS: Windows 10 Home 64.bit
CPU: Intel(R) Core(TM) i7-6700HQ CPU @ 2.6GHz
RAM : 16GB
GPU 0 : Intel(R) HD Graphics 530
GPU 1 : NVIDIA GeForce GTX 970M 3GB
1 Solution
In the graphics setting it is possible to select the dedicated graphics card for your application. It is known from Graphisoft that integrated graphics chips are not recommended for Archicad.
Try to do the above and see if that helps. You may have to restart Archicad for the change to take effect.
Go to post
4 Replies 4
It worked, thank you.
Muriand
What did you do please im facing the same problem
As @Laszlo Nagy  recommend to install your graphic card which is suitable to Archicad rather than relying on the built-in one.
AC 29 INT 4006/WIN 11
