2022-11-29
10:12 AM
2023-11-15
11:56 AM
Aruzhan Ilaikova
Archicad 24 and 25 randomly does not open, crash, hangs and/or become unresponsive when network becomes intermittent, slow or there is no connectivity at all.
This leaves users unable to open Archicad directly from the launch icon or from any .pln directly and often leaves the computer inoperable and unresponsive with the explorer crashing.
Did not notice this issue on older editions of Archicad or on previous versions of Archicad 24 before updates.
2022-11-29 10:25 AM
Are you using network licenses or have you downloaded a software license or have a local USB key?
Network licenses can be an issue if the connections are bad.
Software or local USB should be fine as Archicad only has to look as far as your local machine.
2022-11-29 10:29 AM
Softkey, this issue happens on quite a few of the companies workstations
2022-11-29 12:14 PM
another reason why I prefer USB dongles...
2022-11-29 10:50 PM - edited 2022-11-29 10:54 PM
If you have the softkey, and it is "already" downloaded to your workstation or laptop, there shouldn't be any need for internet connectivity to launch the software. This is my method and aside from that "controversial" re-authentication process I mentioned a few posts back, it runs fine when not connected.
2022-11-30 02:39 AM
Explorer is crashing? Not just AC?
On these occassions, is it just opening AC from .pln files that is slow or the root program as well?
When Network becomes intermittent? Or when Internet becomes intermittent?
If it is actually your network and not just your internet, are the projects stored on an office server? If so, you can go into your registry and change the time out duration. This will reduce any "hang time" caused by being unable to communicate with the server at the time when you attempt to open the file and instead return the unable to open error earlier.
Ling.
