Wednesday - last edited Wednesday by Karl Ottenstein
I recently updated Archicad 28 with the latest build, since then archicad has been constantly crashing...Anyone facing a similar issue.
I tried working on 3 different projects and facing the same issue, not sure what the solution is unless there is a new update...
let me know.
Caleb
Operating system used: Windows 4000
Solved! Go to Solution.
Friday
Thank you for your message.
The Bug Report ID that I had yesterday was :
ac28-2025-02-20-18-51-55-6146
I would be glad and thankful to have your feedback on this matter.
Regards,
Kévin PAIVA
HK ARCHITECTURE
Friday
Hi @HK ARCHITECTURE,
Thanks for the quick response! This issue is registered under the DEF-23306. We'll do our best to fix it in the final update to AC28.1.0.
Regards,
Tamás
Tamás Gáspár
Manager, Partner Technical Support, Graphisoft
Friday
Hello @Tamas Gaspar ,
Does that mean that the bug has been detected and reproduced?
Friday
Disabling distance guides has made archicad stable for me. It crashed like every couple minutes before, now it's been going strong for a couple hours.
Friday
I don't use Distance Guides and I have not have had a crash since I installed the preview.
another Moderator
18 hours ago
Hello Tamas,
Please see below Bug report Id. As mentioned earlier after rolling back to the previous update 28.0.3 (3120), Archicad 28 seems to be stable.
