Archicad Installation
You can download the latest version of Archicad on graphisoft.com/downloads.
Installation and startup troubleshooting guides
Advanced installation solutions
Related articles
Hardware
Installation on Mac
What is installed with Archicad: Where does the installer install components:
  • User specific settings - created after first startup of the program
    • ~Library/Preferences/GRAPHISOFT/ (Work Environment)
    • ~Library/Application Support/GRAPHISOFT/ (DWG/IFC translators, TeamWork local cache - TW Data, etc.)
  • Preferences - created after first startup of the program
      • ~/Library/Preferences/
Java: Starting with Archicad 22 there is no need for Java runtime environment for installing Archicad. In case of Archicad 21 and earlier versions the installer requires installed Java, and if it doesn't find the required version, it installs it. You can check and download the compatible versions from here: Install/Java.
Installation on Windows
  • Archicad to the specified folder, the defaults
    • system drive\Program Files\GRAPHISOFT\
    • Users/<userhome>/AppData/Local or Roaming/GRAPHISOFT (Work Environment)
    • Users/<userhome>/GRAPHISOFT/ (DWG/IFC translators, TeamWork local cache - TW Data, etc.)
    • registry entires: HKEY_CURRENT_USER\Software\GRAPHISOFT
Compatible Java versions: Starting with Archicad 22 there is no need for Java runtime environment for installing Archicad. Archicad 21 and earlier versions were shipped with a Java installer. In case the computer doesn't have Java installed this version will be installed automatically or the outdated Java versions will be updated to this version. There might be problems with Java versions released later than on this list:
  • Archicad 21: Java 8u120
  • Archicad 20: Java 8u72
  • Archicad 19: Java 8u45
  • Archicad 18: Java 8
  • Archicad 17: Java 7
  • Archicad 16: Java 1.6.32
  • Archicad 15: Java 1.6.23
  • Archicad 14: Java 1.6.18
  • Archicad 13: Java 1.6.16
  • Archicad 12: Java 1.6.3
  • Archicad 11: Java 1.6
  • Archicad 10: Java 1.5.0
  • Archicad 9: Java 1.4.2
You can download these versions from here: Install/Java. As a general solution uninstall all Java versions (Control Panel/Add Remove Programs) and the Archicad installer will install the compatible version. For installation or for uninstallation you need to install Java from the Archicad DVD, but installation of Updates doesn't require Java.
Quick Time: GRAPHISOFT used QuickTime, Apple’s multimedia environment in legacy Archicad versions. See how different Archicad versions used QuickTime’s technology’s in the related article of HelpCenter.
