‎2024-07-30 12:26 AM
Constantly having issues with the program freezing when trying to quit, especially with larger files / models. More of a nuisance than a serious problem, but it is frustrating to have to send a bug report nearly every time leaving the program. And have lost work before if I forgot to save before quitting.
Anyone else ever experienced this?
Using AC 26 on MacBook M1 Pro with Sonoma 14.5.
‎2024-07-30 02:14 AM
Do you have the latest update for 26?
Build 7004.
‎2024-07-30 02:29 AM
Believe so. This is what comes up when I check for update from inside program.
‎2024-07-30 02:45 AM
All up to date.
I just did a quick search and found a few posts with the same problem (most for older versions) and the only solution I saw was to update.
If it is not happening to all files, then all I can suggest is you open the files from the file menu with the 'Open & Repair' option to see if that helps.
If not, take note of the bug crash number, and contact you local Archicad support and ask them to follow it up.
‎2024-07-30 02:59 AM
Thank you, will give that a shot.
