blgp
BIMcloud and License Manager Tool for Apple Silicon
Hi there
Since at least most may work with a native Mac version for Apple Silicon (we are unfortunately still eagerly waiting for the CH version) and we have a new server coming, a question about native versions:
Is there already somewhere a native Apple Silicon version of the following two products:
- BIMcloud
- License Manager Tool
The License Manager Tool ist not that important, could also be used on an old computer. But the BIMcloud would be important. We want to set up a new server without Rosetta.
Unfortunately I didn't found any informations from Graphisoft (neither IDC knows anything) and hope for some Informations on this way.
Thanks!
12 Replies 12
I run two BIMcloud Basic servers on a Mac with over a dozen users between the two and 75 GB worth of projects. There has been "no" issues running BIMcloud Basic servers on a Mac.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
blgp
@Rex Maximilian
I'am with you. We run that too. But we've got just one application, which doesn't run natively: BIMcloud. All other made the change to support Apple Silicon natively...
I guess the time should have been enough to make that. 🤞
I recently did a refresh on the BIMCloud we have running albeit it being small.  I noticed when I downloaded the installer the .dmg file is appended with INTEL.  I am wondering if anyone has a silicon mac can try and downloading BIMCloud and see if they have a file appended with SILICON instead?  I guess that Graphisoft has indicated with the INTEL file name appendage is that they need to distinguish between INTEL and SILICON machines for all their software and that a transition is necessary.  The question of when is well . . . . . . . . .
Kind Regards,
Sebastian Monroe
Director/Architect
T: +61 3 9017 6666
www.codearchitecture.com.au
NOM ARCH VIC ARB: 17939
Archicad v26, Mac Mini INTEL 64GB, AMD Radeon Pro
