Hi folks. I digged Google and found the solution. Here's a quote from Intel's website:
The Mobile Intel® 945GM Express Chipset family support hardware acceleration of OpenGL* applications in 16-bit and 32-bit color depths. OpenGL* 1.4 plus extensions is the latest version currently supported by the Intel® Graphics Media Accelerator Drivers. Drivers that come with Windows* or that are downloaded from Windows* Update typically do not support OpenGL*. For optimal performance of OpenGL applications, install the latest graphics drivers from Intel. Also, exit any running background applications, such as virus scanners, NetMeeting* or any programs that run in the task bar.
You can download the latest Intel GMA 950 driver from
here. Before installing this driver, make sure you uninstall the old driver. You should download the driver in ZIP format because the EXE driver won't install properly by running Setup.exe. Windows brings up a message that the driver is not validated which is a driver bug that Intel hasn't taken care of yet. After downloading the ZIP, unpack, run Device Manager, right-click the video adapter and choose "Update driver". Then point to the location of the extracted driver files and you should be fine. Hope this helps. Cheers to everyone!
