Does any one get this when trying to enter text into a label string?
The edit window hardly shows any height and goes full width of the screen.
Temporarly using 2.0 dual G5 mac
Cheers John
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
Hiya Ben,
Height of text is 2.5mm and happens (not always) when i click into the text part of a label on screen
I've tried a new and reset too
Beautiful Day in Sydney
Cheers John
I have had the same experience, but it is erratic and sporadic. Have not noticed a pattern.
Rude comments, clicking in somewhere on the screen, trying again after scrolling and/or zooming a bit seems to fix it until the next time. It is annoying.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
I only noticed this when I switched to using a 2.0G G5. I will see if it occurs next week on my normal machine.
Cheers John
This will be no help what-so-ever, but it used to happen to me every time I used the text tool. One day it started acting correctly and it hasn't acted up since. Darned if I know.
Dave Jochum J o c h u m A R C H I T E C T S http://www.jochumarchitects.com MBP 16" (M1 Max) 64 GBā¢OS 15.6.1ā¢AC 29 Silicon (latest build)
Thanks Andor. The only time this has happened on my current computer (see sig) is as a result of events you have described.
On a G5 (dual2.0) it occured when the text box (actually a label) was clearly visible. More recently, when using the G5 again I havent had the problem.
Cheers John
