COMPOSITE WALLS IN 3D VIEWS
Takis
Hi, composite walls in 3D marquee view are not displayed correctly, both in AC19 & AC20.
Comparing the same structure with normal walls, they do not appear any problem.
I have tried to change material priorities but you get something, you loose something else.
Please try it out.
Takis
Takis
Problem appears where in "Filter and Cut Elements in 3D" window the "Cut
Surface Display" selection is "Use Element Attributes". If "custom" is selected instead, then no problem appears.
Takis
Takis
Hi, talking with Archicad Distributor/Re-seller in Greece, they temporarily solved the problem.
Just click to pick those composite walls and change their structure to "custom" instead of composite.
This solves the problem for the time.
Thanks.
Takis.
