‎2003-12-22 09:53 PM
‎2003-12-23 04:20 AM
Quito wrote:Why do you need the 3D window so large? Are you saving the 3D window as an image?
I'm trying to make a hi-resolution 3D rendered perspective for use in Illustrator (final size 16" x 12") and am having difficulty getting the image to fill the entire large 3D Window (set at 3000 x 2400 pixels).
‎2003-12-23 10:46 AM
‎2003-12-29 09:29 PM
‎2003-12-30 05:13 AM
Quito wrote:The only important relations between the photorendering and the 3D window are:
For some reason, the photorendering DOES work sucessfully at the large size (but not quite as large as my indended size stated previously), I just had to wait for the Photorendering window to complete. It wasn't showing correctly in the enlarged 3D window, which I was assuming had to be set at the same size as the intended final Photorendering Window Size. (I realize this maybe be unclear, but it's difficult for me to describe under the time pressure I'm in!)
