Can't open a file
Created and worked with the file on Windows, then switched to Mac and it dosen't open anymore. Is this problem can be solved? Thanks in advance!
2 Replies 2
Eduardo Rolon
This is actually impossible since AC files will open regardless of platform.
Check that you copied the correct file and/or that you have the same version of AC (i.e. AC22 will not be able to open an AC23 file).
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Guru
What actually happens when you try?
