Changing composite dimensions
Hi there can anyone help me with a problem that i got, im using archicad on window XP pro, i have no problem with using archicad but there is only 1 thing that i can not change the composite structures dimension on, when i clicked on the composites menu, a popup menu came up but its does not poup down the Edit Selected item, the Edit skin and Line Structures is OK. Therefore i cannot change the dimension. Any help please thanks alot
lovetrain
15 REPLIES 15
in Preferences-Dialogs and Pallettes, try switching off the option to auto-close panels
just an idea
Djordje
Ace
lovetrain wrote:
Oh yeah one more thing i have'nt mentioned. When i clicked on the Edit Selected Item arrow the pannel quickly drop down and it goes up again, so its tricky tho, its open but its goes up again, is this a Bug problem or something esle ?
Are you clicking once or doing a long click? It might be the panel understands that is should close. Check the status of "Close panels if the dialog box cannot accomodate more panels" in the Preferences. Also, increase your scren resoultion if possible; IMHE 1280x1024 is the minimum manageable, 1600x1200 is comfortable.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
BILLLLLLLLL SHORTENNNNNNNNN
thanks i got it now hihihi, thanks again people for yours help i'm really appreciated.
thanks all.
lovetrain
Thanks Djordje
thankyou for ur help, I've solved the prob now , thanks all people
lovetrain
I meant you should try downloading the latest drivers for your graphics card. I may be a driver problem.
Laszlo
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, Ac20-Ac27
Loving Archicad since 1995
Sorry, I just see it got solved.
Should have read the 2nd page of posts as well.
Laszlo
