Installation & update
Crash while editing text in Label Tool
alexliz
Not sure if I'm posting in the correct area for this, feel free to move if not.
I'm getting Archicad crashes pretty much every time I go into an existing Label Tool text to edit it. Anyone else reporting similar issues? I'm on the latest 27.1.2 Hotfix INT 8060 4060.
Operating system used: Mac Intel-based Sonoma
Archicad 27 macOS Sonoma
There is a preview update 27.2.0 build 5001
It is available for some language versions.
https://graphisoft.com/resources-and-support/downloads?section=update&localization=AUS&type=FULL&ver...
Choose your language version and see if it is available.
Aaron Bourgoin
it's a Sonoma thing. Disable your CAP-LOCK key.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Thanks Aaron!
Setup info provided by author
