Critical error in AC9
I have been working in AC for several months on the same project and all over sudden it crashed for the first time. Then it crashed 6 times in 15 minutes. The bug report was send, but should i hold my breath to get contacted by Graphisoft? One of the Bug Report Codes was:
2005-01-14-19-14-53-4149
Should i start a new file and merge the project? Any suggestions are welcome.
16 Replies 16
Before you do anything go to C:\Documents and Settings\user\ApplicatiDataGraphisoftArchiCADhiCAD 9.0.0 USA R1 and trash any thing with a .prf extension.
Next, if that doesn't fix it, you should try to figure out if there is a specific action which causes the crash. Did you get any error messages
Third, I would save the file with a different name.
Fourth I would open a new and reset file and merge the project into the new file.
Don't wait for Graphisoft to call and the number alone is meaningless.
See above... if this doesn't help call you support provider.
Woody
Thanks for your help.
To double check, delete everything in the attached image?
(Also what should i do with the *.dmp files?)
TomWaltz
Graphisoft will not contact you. The Report Code is just the date and time that the problem occurred.
Woody's ideas are all potential fixes.
Tom Waltz
Anybody know what this means?
C:\Program Files\Graphisoft\ArchiCAD 9\ArchiCAD.exe
Unused in temporary folder : 162777.9 MB
Unused in temporary folder : 162586.7 MB
Projection : Isometric axonometry
Camera azimuth : 270
Start time : 14/01/2005 19:53:06
End time : 14/01/2005 19:53:06
Elapsed time : 0 seconds
This plan is corrupt.
The saved output may not contain some elements from the plan.
Unused in temporary folder : 162569.9 MB
Unused in temporary folder : 162559.5 MB
Projection : Perspective
Eye position : 117.649 -2.19885 1.5
Direction : 0.643848 0.765153 0
Distance : 26.223 Angle : 70
Start time : 14/01/2005 20:08:31
End time : 14/01/2005 20:08:31
Beginning generation of Section/Elevation:
Start time : 14/01/2005 20:09:11
Document name : Amhurst Mother File.pln
Processed : 0 walls 0 objects 0 columns 0 ncBeams
End time : 14/01/2005 20:09:11
Creating section
Projection : Side view
Finished generation of Section/Elevation.
Just the ArchiCAD 9 Basic.prf
Ben Odonnell
I beg to differ.
This number can be in fact quiet helpful. If you get in contact with you local ArchiCAD support and give them the number, they can then contact GS give them the number and the can then go in and have a look at the bug report. If you are lucky they may even be able to tell you what the problem is.
I always request our customers to give me this number, it helps GS as well.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Ben Odonnell
Again,
Contact you support. *.dmp files are also very useful for GS.
Ben
Ben O'Donnell
I will do that! THanks.
Link
You tell 'em Ben!
And on a side note, from memory you can merge a new & reset (empty) project into a problem file to fix it. It's called forward merging and saves you recreating a whole bunch of stuff, including viewsets.
This technique may be outdated, but it's worth a try!
Link.
