I'm having a problem with my curved wall edge not showing in the elevation window. I've tried everything and nothing fixes the problem. As you can see from the 3d image there is a wall there.
Are all your walls in the same layer? If you use view sets with layer combinations perhaps the layer combination assigned to your elevation view don't include all the necessary layers.
