2016-07-08 10:39 PM
2016-07-08 10:51 PM
another Moderator
2016-07-09 12:11 AM
2016-07-14 09:25 PM
2016-07-15 03:11 AM
2016-07-15 09:25 AM
2016-07-15 04:40 PM
Barry wrote:I replaced my keyboard about a month ago, because I do admittedly wear out my escape key and space bar. Same with my mouse, I wear out the scroll wheel and have to replace it every 4 to 6 months.
The ESC shortcut is non-customisable so it shouldn't be affected by the Work Environment.
It is working fine for me but I only have the pre-release version and Windows 7.
I would be guessing there is some other program (or a Windows setting - but I have no idea what) that is blocking the ESC key.
Does it work in other programs.
Do you have an older version of Archicad - is it only 20 that has the problem?
If so then I would be guessing it is an Archicad 20 issue.
Can you start Windows in safe mode and then run Archicad to see if it works then?
2016-07-15 05:30 PM
2016-07-15 06:40 PM
2016-07-15 11:22 PM
