KeesW
Edit color error
There is a problem in my Australian AC24 Template. I am unable to edit colors or ascertain their RGB values because the Edit colot box only partially appears when a color is selected from the Pens and Color Model views. See attached screen print. Is this a bug or something I've forgotten?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
10 Replies 10
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Unfortunately, I'm still unable to reproduce it on the native screen of my laptop. Previously I had used 175%, until I found my eyes hurt after a full working day. Even then I had no cropped dialog issue. I tried with 125% and 225%, but the dialog still scales nicely, even if I start Archicad from scratch, or adjusting the scaling while AC is running.
I still think that it somehow relates to external display. I remembered coming across this issue once with an external 4K monitor, but it was long ago that I can't remember which AC version it was.
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
