Installation & update
Exploding Text Not in Archicad 11??
Dwight
Was there ever a time where one might explode text into vectors and fills or am i dreaming?
Dwight Atkinson
19 REPLIES 19
Eduardo Rolon
AFAIK you could do it in Autocad, but AC nope.
That's what Illustrator is for.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Rakela Raul
i remember when i wanted to create a line style with text on it, it seems that i exploded a text and used those lines for the new line text abv it...
it could have been a dream though !!!
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Dwight
I betcha they can do it in KetchUp.
Swell. I used illustrator - since it puts text in a circle and i am designing a glowing medallion, things are going to work out fine.
Dwight Atkinson
ta da!
http://archicad-talk.graphisoft.com/viewtopic.php?p=19701
Explode the 3d text library part. Don't forget to have 'show view in 2d' on.
Eduardo Rolon
Dwight wrote:
I betcha they can do it in KetchUp…
Yes they can by using the 3D Text tool and then exploding it.
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Hey, it is the same procedure, maybe GS is "stealing" from Google.
And it is easier in SketchUp.
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Now we need Push-Pull.
AC29 US/INT -> AC08
another Moderator
I think the 3d text library part had been in ArchiCAD long before Sketchup came along!
Eduardo Rolon
That is not the point, SketchUp has it so it does not matter that AC was first, SU's is easier…
AC29 US/INT -> AC08
another Moderator
