Dwight
Exploding Text Not in Archicad 11??
Was there ever a time where one might explode text into vectors and fills or am i dreaming?
Dwight Atkinson
19 Replies 19
Dwight
Whose dad can your dad beat?
Dwight Atkinson
ejrolon wrote:
That is not the point, SketchUp has it so it does not matter that AC was first, SU's is easier…
Ahh, fair enough. Shall I start a poll demanding that it should be made even easier than Sketchups?
So easy, in fact, that I only have to gesture towards the screen and it gets done. A bit like Dwights Avatar, but one handed.
Dwight
Yes, but by using two hands in a mere symmetric gesture, I can describe entire structures including their details and written specifications if anyone on staff had the skill to interpret my genius.
I am sure other employers share this problem.
Dwight Atkinson
Dwight wrote:
... if anyone on staff had the skill to interpret my genius. I am sure other employers share this problem.
I assume your next book will have a chapter on this obviously important but seldom taught subject. I look forward to the day when an architect can gesticulate with wild abandon and not be greeted with blank stares or barely muffled sniggering.
Eduardo Rolon
Isn't That what Gehry already do?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Dwight
You offend against a great mind. Our Guru Gehry wouldn't wave his arms like my idiot boss did.
He would crumple tracing paper up into meaningful balls, stick them together and have them digitized. You'd only smirk once at that until you saw how well it worked.
Dwight Atkinson
Eduardo Rolon
If you see "Sketches of Gehry" it is more construction paper, scissors and transparent tape, then a crew of slaves doing a full model, then digitized. If I remember correctly there was some hand waving maybe more orchestra conductor than "Dwightish".
AC29 US/INT -> AC08
Dwight
slaves.
Dwight Atkinson
Eduardo Rolon
Sorry, it should have said;
…recent architecture school graduates…
AC29 US/INT -> AC08
When I need to explode text i do it in Autocad. It is just a simple command: "Explode text"!
