ā2008-06-05
12:16 AM
ā2024-05-03
11:55 AM
Aruzhan Ilaikova
ā2008-06-05 02:17 AM
ā2008-06-05 04:50 AM
ā2008-06-05 04:36 PM
ā2008-06-05 06:14 PM
ā2008-06-05 06:33 PM
ā2008-06-05 06:39 PM
zucoc wrote:Hmmm ... if you say so
right-click on a PLN file -> open with... -> select the version of archicad you want to be the default to open -> check the checkbox with always use the selected program... -> click ok
and that's it
ā2008-06-05 06:49 PM
zucoc wrote:That, may be the standard Windows procedure, but it doesn't work for me (note the original comment). When I try to select a different version in the 'Open With' dialog box, it still defaults to whatever version it wants. Looks like we're stuck with opening ArchiCAD and then browsing to the file, though if Graphisoft wants to fix that, I'd love to see it.
and that's it
ā2008-06-06 04:00 AM
BasisArchitecture wrote:You can always set up an Archicad shortcut on your desktop.zucoc wrote:That, may be the standard Windows procedure, but it doesn't work for me (note the original comment). When I try to select a different version in the 'Open With' dialog box, it still defaults to whatever version it wants. Looks like we're stuck with opening ArchiCAD and then browsing to the file, though if Graphisoft wants to fix that, I'd love to see it.
and that's it
ā2008-06-06 07:17 AM
Barry wrote:Thanks for such a nice tip Barry.
Then just drag and drop the file from Explorer onto the shortcut and it will open.
