Fill background pen not changing.
I tried to change the background fill pen in a 'fill', but it wouldn't change from transparent in the plan window. It did change in the dialogue window though. I was trying to make an informal patch to cover an unwanted wall. I also moved it to the top of the viewing order. Only noticed this in v8.1. In desperation I used a thick white pen - this did work.
v8.1, Dell, windows xp.
Any ideas?
4 REPLIES 4
Check Options > Preferences > Miscellaneous.
The fill background setting is probably set to "All transparent". Change to "Use elements' settings" and it should show as you wish.
Quite right - thanks a milliion. When did they slip this little beauty in I wonder!!!
Djordje
In 7 ... 😉
I always forget to set it, as IMHO it should be in Display options, not in Preferences/Miscellaneous! Yes, there is a wish already! 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
In 7 ... 😉
Yes, this one is long overdue for promotion from the Preferences/Miscellaneous probationary holding cell for new features.
