Scott Bulmer
Fit Frame to Drawing default not sticking (AC14)
After setting the Drawing Tool to 'Fit Frame to Drawing', dragging in a view onto a layout sheet causes the placed drawing to become 'Manually Resize Frame.' Even if I change a placed drawing to 'Fit' then pick up the attributes (option click), newly placed views still come in as 'Manual.' I have New & Reset that does not make a difference. Any thought will be appreciated!
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
2 Replies 2
Does the view you are dragging in have a zoom area saved with it? Try it with the "none" setting.
Scott Bulmer
Stuart! Great idea! Setting the view to 'Ignore view when opening this view' had no affect. BUT, setting the view to 'Fit in window' did the trick.
Thank you for saving me more hours of grief.
Scott
