2007-09-24 04:47 AM
2007-09-24 04:51 AM
Rossjk wrote:sounds like your TAB key is stuck down . . .
Its getting really annoying when i'm not quick enough to select something before the highlight disappears (it acts as if i have let go of the shift key...)
2007-09-24 05:04 AM
2007-09-24 05:11 AM
Rossjk wrote:TAB is used by the preselection system to scroll through overlapping elements . . . hence why i thought it might be stuck.
Tab's working fine.....Its more like there's an auto repeat happening on the shift key
Just discovered it does it when using the Alt key alsoTAB is also used when you want to select overlapping elements to syringe up their parameters using the ALT key, so . . . are you SURE that the TAB key isn't stuck down?
2007-09-24 05:34 AM
