Installation Problem
Hi, i just downloaded Archicad 19 INT, but i cant install it.
i always open it with adminastrator rights, but the installer opens and close in a second, without having the chance to do anything.
im running windows 10 pro last updates
UAC is off, same as antivirus and firewall
java is updated aswell
and my pc is an asus g752vy, which is more than okey for archicad.
thank you very much
12 Replies 12
This may not be related but the NVidia GeForce Experience application is another one that is known to cause problems with ARCHICAD:
http://helpcenter.graphisoft.com/troubleshooting/performance/archicad-18-performance-troubleshooting...
Hello, i would like to know if you find a solution for your problem? im having the same issue with the same laptop and i really need help because i got this pc to work faster and now im wasting alot of time by not installing archicad.
any help would be really apreciated.
thanks!
Hello, after trying many times i found that you can install the software when you open you laptop on safemode, in there you have to install the Java versión that archicad needs and after that you can install the program without problems.
i still dont know why we cant install the program normaly and if is a issue of the laptop or the OS with the program because i could not find any other way to do it.
hope you are still interested.
Thanks!
