‎2022-07-20 03:23 PM
I've installed Goodies pack on my Archicad 26 but I can't see the Accessories it into the path design>extra design>accessories. Solution?
‎2022-07-20 04:24 PM
Did you load the accessory library?
It's a separate library from the main one, at least on v24
‎2022-07-20 05:15 PM
Did you install the correct language version for the goodies?
The same as you Archicad language version.
Or do you have a custom Work Environment active?
Check the Add-on Manager to see it is installed properly.
That will also tell yo the location of the commands in the menus.
‎2022-07-20 05:41 PM
YES, I load library
‎2022-07-20 05:46 PM
I downloaded the Italian version as my Archicad, but when I check the Add-on Manager the files .apx are in english. What can I do?
‎2022-07-21 04:05 AM
I guess un-install the English Goodies.
And then install the Italian ones.
https://graphisoft.com/it/downloads/goodies/ac26
‎2022-07-21 05:18 AM
I have no Accessory file in Archicad 26
‎2022-07-21 05:30 AM
It looks to me as if Archicad 26 dose not have the Accessories anymore. Big loss to me.
Is this a reduced cost upgrade/version or something. It seems to me that it is not as functional as 25, which was only a very marginal improvement over 24.
‎2022-07-21 05:39 AM
So you have installed the USA goodies?
Do you have the commands in the menus?
If you do and you have no library objects, you must manually load the Accessories library that is located in the Program folder for Archicad.
If you don't, then can you show a screen shot of you Add-on manager.
‎2022-07-21 09:14 AM
I know. I downloaded the file . exe from that directory (https://Graphisoft.com/it/downloads/goodies/ac26)
the file is also contains "ITA" in the name
