pones
Launching AC with custom work environment through command line?
Hello all,
I've seen it's possible to force AC to launch through commercial or EDU license, using command line codes.
Is it possible to force AC to use a different work environment through this process?
More generally, does someone know what are the possible command accessed by the command line in launching the software?
Thank you!
7 Replies 7
runxel
There is no official list that I'm aware of.
And since there is none published it seems that it is also not really wanted (?).
In your case tho you can try the -useprofile= flag.
Ricardo Lopez
Hi @pones
As seen on the Archicad 29 Help: Comman Line Parameters (Custom Install)
You can install predefined company standard defaults for:
  • Work Environment,
  • Archicad Template, and/or
  • DXF-DWG Translators
In te command line, type the executable file name followed by: --customEnvironment
followed by the path of the Defaults folder containing your preferred files.
For info on how to set up the Defaults folder, see Customized Company Defaults for Unattended Installation.
Ricardo López, M. Arch.
pones
Hi Ricardo,
Thanks!
But I’d like to address automatically a different work environment without having to reinstall AC every time I wanted to do so…
For instance, if in my office I work with architectural design and urban planning, I’d like to setup two different shortcuts for each case.
I couldn’t find any document about it, but I’ve presumed we could launch AC with other custom properties than the one described for forcing the commercial license (noedu) in the command line.
pones
Hi Lucas,
It doesn't work. When I start AC, it shows the startup window that asks to specify the model from which we'll create a new project, and to select the user profile we want to use. I'd like to bypass this window or at least, to force it to select a named user profile...
runxel
So you don't want to open an existing file but make a new one?
pones
It doesn't matter. Even if I open an existing file, the syntax -useprofile=myprofile doesn't seem to work.
Charlie64
I had that problem. Following this I don't have that problem anymore.
https://community.graphisoft.com/t5/Licensing/Run-ARCHICAD-Educational-along-with-Commercial-version...
