2008-04-09 04:52 PM
2008-04-11 05:47 PM
2008-04-11 10:26 PM
2008-04-11 10:44 PM
2008-04-12 02:02 PM
Todd wrote:No. All the objects could have the same ID number, it is just a user assigned parameter. Some object utilize the ID number (for example a door might use it for its designation for the marker and for scheduling), so the ID number can be used in an object's script, but it is unlikely this is your problem, as Djordje said, you probably have a bad parameter, or it is possible that the archive did not include one or more macros, which are additional scripts called by library parts. But the first step is to look at the problematic parts individually.
Is there a problem if several objects have the same ID number?
