We value your input!
License Tool Manager error installation
Avanti
Hi, after we installed Archicad 26 Solo INT Apple Silicon, we wanted to download the license that we purchased using the License Manager Tool. But the LMT didn't installed, there is an error in the installation. The same thing occurred installing Archicad 26 INT.
See photo attached.
I'm using a very new M3 Macbook Pro. Sonoma 4.3.1.
Please help.
Operating system used: Mac Apple Silicon Sonoma 4.3.1
2 ACCEPTED SOLUTIONS
Nurbs
Try to download License Manager Tool again. Then open System settings and give "Full disc access" to the LMT installer. Run the installer afterwards.
https://graphisoft.com/downloads/licensing/help/INT/mac
AC16 - AC aktuelll , WIN 10
Ricardo Lopez
Hi @Avanti
Try to download and reinstall just the GS License Manager Tool alone from: https://graphisoft.com/downloads/licensing/help/int/mac
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Nurbs
Ricardo Lopez
Hi @Avanti
Regards.
Avanti
Thank you, that solved the problem.
Setup info provided by author
