2013-10-23 09:22 AM - last edited on 2024-03-28 10:01 AM by Aruzhan Ilaikova
2013-10-30 02:05 AM
2013-10-30 03:23 AM
drh64 wrote:That's great news. Shame about so much work on your side by basically starting on a clean system.
Everything still seems to running fine.
2013-10-30 02:55 PM
2013-10-31 01:47 PM
JaredBanks wrote:Hey Jared, so far we have no such reports. Please get in touch with our US team and they will help your client to address this. We would need process samples created when the 20 sec hangs are happening to check what might be causing it.
Anyone else noticing this?
2013-10-31 01:53 PM
JaredBanks wrote:Have noted something like this, let me see how it goes today.
I don't know all the details, but here's another issue I learned about from one of my users in Minnesota:
"We installed it (OS X 10.9) on a couple of machines and found that in general, it works. One item we observe is that when switching apps (while AC is running), we sometimes see mouse and keyboard freeze for about 20 seconds. The computer seems to be working through this, but input is not possible. This does not lead to crashes or any problems, it is just an annoying item. App nap is disabled for AC, so that is likely not the driver for the issue. "
ALSO...
I noticed in this thread we haven't linked to the Compatibility notes. SO here they are:
http://archicadwiki.com/OsxMavericks
and then a post with some other links and bits of advice about system upgrades (and links for Windows 8.1).
http://www.shoegnome.com/2013/10/23/compatibility-note-archicad-on-windows-8-1-os-x-10-9-mavericks/
another Moderator
2013-10-31 02:22 PM
2013-10-31 03:00 PM
2013-10-31 04:02 PM
FuzzyWill wrote:Worth repeating: Anyone upgrading should (must?) read this article first:
Testing AC17 on Mavericks on brand new MacBookPro: AC17 worked perfectly before upgrade - after upgrade, AC wouldn't recognize license key.
2013-10-31 04:16 PM
Marton wrote:Thanks, Marton! I'm quoting in full to draw more attention to your post... would like to make the post a 'sticky', but can only do that to a fresh thread.
A quick heads-up to summarize the situation on 10.9. All known problems are documented here: http://archicadwiki.com/OsxMavericks If you notice anything new, let us know or get in touch with your local GS office or reseller.
As for the different versions:
- ArchiCAD 16 and 17 works well on 10.9, we maintain compatibility of these on 10.9
- ArchiCAD 13 - 15 works, but there are some problems. These won't block your work, but will cause difficulties. Like saving PDF terminates the program in v13.
- ArchiCAD 10 - 11 (12) are crashing at startup, so these version basically cannot be run
- ArchiCAD 9 and older version cannot be run as those are PPC applications and Rosetta, the environment that would allow us to run PPC apps on Intel powered Macs has been discontinued
This compatibility list raises one important question - conversion of older files. At the moment we have version 7, 9 and 10 file converter packages. Non of these run on 10.9, so the oldest file version that can be opened on 10.9 is 8.1. We are checking what better possibilities we have.
Some additional info:
- http://www.graphisoft.com/downloads/fileconverter.html
- file compatibility chart (at he bottom) http://www.archicadwiki.com/ArchiCAD%20versions
2013-11-01 09:01 AM
