2023-09-27 04:45 AM - edited 2023-09-27 04:02 PM
macOS 14.0 Sonoma was released today (September 26, 2023). Every year, a bunch of folks immediately upgrade and then start posting here about things that don't work. Don't be one of those people 😀 Instead, first read Norbert Kucsma's official Graphisoft article on Sonoma compatibility here:
https://community.graphisoft.com/t5/Installation-update/macOS-14-Sonoma/ta-p/385787
Edit: See Norbert's message below that 26 and 27 are compatible today. However, it is worth reviewing the issues in the article linked above to see if they will impact you enough that you'd want to wait for the next updates to each of those versions.
In particular, note in the article that Archicad 23 and earlier will not even start under Sonoma. If you are still using 23 or earlier, please do not upgrade your macOS!
2024-01-26 10:05 PM
Still an issue with build 4060...seriously Graphisoft?!!
2024-01-30 11:59 PM
Tamas Gaspar from GS Tech Support wrote:
"The development is working hard on the tests of Archicad 27.2.0, which contain numerous bugfixes. We should make sure that the update is being released in proper quality, so this why we need to wait some more days until the release it in the beginning of February."
