Scott Bulmer
Missing Complex Wall Separator Lines
Hello friends,
In the attached image the settings are the same for each Complex Wall. The only difference is that one was custom made from a fill and the other is a standard Complex Wall Profile that came with AC10. Please note that the separator lines are missing from the custom created profile. Is this a bug or am I missing something?
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
15 Replies 15
Hmmm....I'm sorry to say I'm at a loss. I can't get it to work either. Bug?
Anyone else?
Scott,
In an attempt to fix my own problems I stumbled across your post. What I am trying to do now is adjust my floor cut plane located in the document tab. This I'm sure is the tool we both need to fix our problem. The key, which I am still trying to figure out, is how to use it best. The nice thing is that you can set each individual wall to different cut planes so like me, my perpendicular walls are 1/2 a log course off-set, I can then use two different cut planes to get the desired overhead line results. Hope this help, let me know how it turns out for you.
Scott Bulmer
Demetious,
In our problem the cut plane height is not the issue. The plan view generally shows correctly the cut of the wall and the limits of the profile, but misses some of the other projected lines. This is not the end of the world but brings into question consistency. Lines viewed in plan view can vary from profile to profile. See another example of inconsistency attached.
Thanks,
Scott
Scott,
I see what you mean now, sorry for the confusion. I'm not really sure what that means for you but it sounds like your on the right track with an inconsistency. These profiles are not as user friendly as I hoped they would be but they are very powerful because of the many options you can do with them. Maybe my problem then is the same thing you are experiencing because even adjusting the cut planes I cannot seem to get my lines to come out right in floor plan.
TomWaltz
Is the Floor Plan cutting plane cutting through your "wall" or cutting above it?
Tom Waltz
Link
Scott
You've probably figured this out by now, but it may help others...
In reply to your image Complex Troubles 2.jpg, please see my attachment.
The elevation measurement that 'oddly shows to the top of the footing' is to indicate that it really is measured to the local origin of the profile. In the Profile Editor each profile has it's own local origin indicated by a +. That's where the wall's placement height is measured from. You can elevate the wall until the cows come home, but the measurement will always relate to that local origin.
The width is measured from the maximum width of the profile, but you can only change it if you have the horizontal stretch activated.
Link.
