_c_
Network Installation with BIM Collab (AC 26)
We would like to use the network installation. If possible, we would love to batch install a few Add-ons, such as BIM Collab. Is it possible in the option file, or we just set up something else? There is the "--enable-components" option, but it doesn't look like it's the right thing.
Thank you
_c_ | Archicad, Revit und Vectorworks stets in den letzten 2-3 Versionen | Mac 14, Win Pro 11
5 Replies 5
scottjm
Mentor
the --enable-components option is only for the components part of the main archicad install.
The following options for the main archicad installer are available:
ARCHICAD26  (or the relevant version you are installing)
Library
GRAPHISOFTShellExtension
BIMxDesktopViewerInstaller
LicenseManagerToolInstaller
The Goodies Installer has a similar argument to define which goodies you may want to install.
Add --help to the end of the executable to see a list of all the available arguments and their options.
If you want to install other addons, you could need to create a batch script to run their separate installers after you have run the archicad installer.
More info about the arguments for the Archicad installer is available here:
https://help.graphisoft.com/AC/26/INT/_AC26_Help/004_BIMManager_InstallGuide/004_BIMManager_InstallG...
_c_
Thank you Scott, it is then as I thought. I'll do a batch script for the rest.
I indeed would like to install the components and am looking for the proper naming. These should list using the option --help in the terminal:
Command Line Parameters:
--enable-components
followed by a comma-separated list of the allowed (non-default) components to install.
To see list of allowed components: type  --help.
Trying to run the path in the documentation fails, where do we get the installer app?
Archicad\26\Installer.app/Contents/MacOS/installbuilder.sh --mode unattended
scottjm
Mentor
From my limited knowledge of MacOS my guess would be potentially inside the DMG.
I'm a windows user sorry.
_c_
It isn't unfortunately. I tried also to re-install altogether.
Today I'll do it in the office, on Win (I am at home now at the Mac).
It might simply be a copy-paste left over in the documentation from AC 20 or before.
I am on Archicad only since 6 months and reading all I can.
_c_
BUMP
