Installation & update
OS X test lab rats sign up here
Aussie John
Any one tried OS X 10.4.3 yet?
Cheers John
[/size]
10 REPLIES 10
Eduardo Rolon
Installed it (±58 megs if you have your system up to date) on my G5 using software update. No problems detected yet though it took a long time to restart after the instalation and the fans do kick in more often than before. Running Disk Utility to repair permissions afterward the list is longer since aparently they updated the widgets and we get a lot of "using special permission on ..." items, which according to Apple they can be ignored. The only problem that I still have is that I still cannot access graphisoft.com but that has been the case since 10.3.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
__archiben
yep. all ok here for the last 24 hours
i'm still waiting on the whole dotmac webdav issue though: idisk is still very much un-automatic until i hear otherwise . . .
dashboard seems more responsive . . . but i do have 25 widgets loaded on a oldish laptop, so i've never expected miracles of it . . .
no archiIissues. yet. (accessing graphisoft.com has never been an issue either . . . delete your safari prefs and cookies eduardo?)
b e n f r o s t
Eduardo Rolon
Yep. Did it again to be sure, No access... Though I was informed that it might be my ISP and if that is the case then I will never have access again unless I change them to the only other one that we have which does not garantee anything.
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
OK found another way to get in... I can't access www.graphisoft.com but I do have access to www.graphisoftus.com but the SketchUp plugin is in the former so no download...
AC27 US/INT -> AC08
another Moderator
Aussie John
I understand there is built in driver for the mighty mouse- Wonder if this fixes issues some had with it
Cheers John
[/size]
MSotero
This may answer that:
http://archicad-talk.graphisoft.com/viewtopic.php?t=7664&start=40
I upgraded to 10.4.3 yesterday morning. All went fine until I went to lunch. Upon returning, 1/2 hour later, the computer had crashed. Got the dialog box, you must restart your computer. restarted, Sent off the bug report to apple, opened the automatically saved AC plan I was working on and all seems ok. Have not repaired permissions yet but will do that asap. Hope this is not a recurring problem. Have not a clue what caused the crash. Very interesting.
Upgraded night before last on my PB 1.5 15" -- so far no problems and it seems to do some things a little faster. At the office I still on 10.3.9 and there is a difference. Very solid. AC works quite well. (9.0US 2045)
Lew Bishop
PB 15" 1.5/1.5GB/80
AC9US
Chazz
Ditto on the fans. Even after I tried this
Dashboard much snappier though.
Nattering nabob of negativism
