Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Installation & update
Please Help me with ArchiCad Tutorial\Manual
Hi this is my first post I'm Onome Igho and i'm studying architecture in Fedral University O Technology Yola please i like someone to help me with a manual/tutorial on ArchiCad 11 or 12.
6 REPLIES 6
correct me if i'm wrong...
are you asking for help to create a manual/tutorial document for AC11 & 12? or you want someone to teach you these AC versions?
In the Help menu you can find links to the Help files both in HTML and PDF format.
You can also download Interactive Training Guides for ArchiCAD from the following page:
http://www.graphisoft.com/products/archicad/training_guides/
Hi please how i need you with a manual for revit architecture 2008 or 2007 and a manual for 3dmax design 2007 or 2008
onome wrote:
Hi please i need you to help me with a manual for revit architecture 2008 or 2007 and a manual for 3dmax design 2007 or 2008
Why post this on an ArchiCAD forum?
It would make sense to try the site of the company that develops them -
Max - http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9861583&linkID=5604642
Revit - http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5106957
Hi I'm Andri, I want to download the archicad tutorial, but the file seems to large and I need a lot time to download. Have you a solution, maybe the tutorial can be divide into several file, so I can download it.
thank you
I think you will not find it in smaller pieces because it is a single installation file. Like some of these game demos: their file size can be 1-2 GB.
Maybe you should use a download manager program. It can download in several threads plus you can stop and resume the download process.
One such program is called GetRight.
