‎2014-09-16 02:55 AM
‎2014-09-17 01:11 PM
‎2014-09-18 07:44 AM
‎2014-09-18 08:18 AM
‎2014-09-18 09:19 AM
‎2014-09-21 06:07 AM
‎2014-09-21 07:51 AM
SenecaDesignLLC wrote:I'm using windows 7 and have the memory leakage problem in AC 18 exactly as you describe. The odd thing is that I never had this problem before in AC 17 so it never occurred to me to go back and test the issue in 17. Turns out 17 can't handle multiple instances of AC anymore either. Very odd: I wonder if one of the recent Windows Updates might have changed something in the OS that's causing this?
I am also experiencing this issue...
‎2014-09-21 01:38 PM
David wrote:It has to be. I used to have no issue. And thank you for verifying that the issue is there for 7 too. I was about ready re install windows. Maybe I'll try to uninstall some windows updates and see if I can narrow it down. I've had the issue since right around the release of 18 maybe a little before that. I'll let you guys know what I find out. Hopefully this gets fixed soon. Puts a huge damper on being able to have a good work flow.SenecaDesignLLC wrote:I'm using windows 7 and have the memory leakage problem in AC 18 exactly as you describe. The odd thing is that I never had this problem before in AC 17 so it never occurred to me to go back and test the issue in 17. Turns out 17 can't handle multiple instances of AC anymore either. Very odd: I wonder if one of the recent Windows Updates might have changed something in the OS that's causing this?
‎2014-09-22 04:11 PM
‎2014-09-24 05:29 AM
SenecaDesignLLC wrote:yes this is the same from me.. every so often its fine.
not sure if there is any consistency but i occasionally get lucky and can open multiple ac instances no clue what i did if anything to make it happen though. its maybe 1 in every 15 or 20 tries that it even happens
