Possible bug? Multiple AC Windows
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-09-16 02:55 AM
ever since iv moved to AC18, more often than not, if i have an AC window open (A) and i open a second (B), window A will struggle extremely while B will cruise along without issue.. A is so bad i will have to close it and only reopen it after i have shut B back down.
is this something anyone else is experiencing? or known problem?
cheers
Gene
- Labels:
Performance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-17 01:11 PM
so far we haven't had similar reports with regards to ArchiCAD 18, so we should investigate this from scratch.
When you have two ArchiCAD sessions open, there is communication between that two. That brings the possibility to e.g. drag and drop content in organizer between the two projects and things like that.
A few ideas:
- try to open two empty files (ArchiCAD stock template) to see if the slowness arises
- close all other applications for a test, temporarily disable the AntiVirus software (before that disconnect all network connections)
- if you have a network license, try to connect the license key directly to the computer
Let me know the results,
Marton
Chief Product Officer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-18 07:44 AM
I've also seen this behavior, as reported here:
I'll make some trials as you suggest and report back.
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-18 08:18 AM
david, it would be great to hear from you if you have any success also.
cheers
Gene
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-18 09:19 AM
system is
i7 3.50GHz
16gb ram
nvidia GTX760 3gb
64bit Win8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-21 06:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-21 07:51 AM
SenecaDesignLLC wrote:I'm using windows 7 and have the memory leakage problem in AC 18 exactly as you describe. The odd thing is that I never had this problem before in AC 17 so it never occurred to me to go back and test the issue in 17. Turns out 17 can't handle multiple instances of AC anymore either. Very odd: I wonder if one of the recent Windows Updates might have changed something in the OS that's causing this?
I am also experiencing this issue...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-21 01:38 PM
David wrote:It has to be. I used to have no issue. And thank you for verifying that the issue is there for 7 too. I was about ready re install windows. Maybe I'll try to uninstall some windows updates and see if I can narrow it down. I've had the issue since right around the release of 18 maybe a little before that. I'll let you guys know what I find out. Hopefully this gets fixed soon. Puts a huge damper on being able to have a good work flow.SenecaDesignLLC wrote:I'm using windows 7 and have the memory leakage problem in AC 18 exactly as you describe. The odd thing is that I never had this problem before in AC 17 so it never occurred to me to go back and test the issue in 17. Turns out 17 can't handle multiple instances of AC anymore either. Very odd: I wonder if one of the recent Windows Updates might have changed something in the OS that's causing this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-22 04:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-09-24 05:29 AM
ill install AC17 on the win8 and see if its doing it.
SenecaDesignLLC wrote:yes this is the same from me.. every so often its fine.
not sure if there is any consistency but i occasionally get lucky and can open multiple ac instances no clue what i did if anything to make it happen though. its maybe 1 in every 15 or 20 tries that it even happens
i thought it had something to do with trying to work ion the original window while the second was opening. but iv tried this recently a few times and no luck.. just seem random (by very rarely)
