Possible bug? Multiple AC Windows
ever since i started using AC (ac11) I very commonly have 2-4 AC Projects open at once bouncing back and forth between them. iv not had a single issue doing this from in any of the versions (11, 12, 13, 14, 15, 16, 17)
ever since iv moved to AC18, more often than not, if i have an AC window open (A) and i open a second (B), window A will struggle extremely while B will cruise along without issue.. A is so bad i will have to close it and only reopen it after i have shut B back down.
is this something anyone else is experiencing? or known problem?
cheers
Gene
16 REPLIES 16
i was contacted by graphisoft to try a couple things, im guessing the rest of you were as well. I tried what was suggested with editing the ipcconnection in the registry editor. i set the disable to 1 instead of 0. i can now open multiple ac windows with no issues. i can also still copy and past from one to another.
i havnt had a chance to try this yet.. im not to "computer smarts" so iv been avoiding it in case i stuff something up.
i wonder why this issue is happening for some and not all?
i just did this to mine also, and seems to have fixed the problem
You just save my day.
I was going crazy not being able to use two or more session of archicad at once.
David Collins
In my case the problem seems to be insufficient memory. While the 4GB RAM that I have is the minimum required to run ArchiCAD, Csaba KƩzƩr at Graphisoft Technical Support advised me that you really need 4GB for each instance of ArchiCAD in order for both to run safely and quickly. Disabling the IPconnection in the registry didn't work for me: a second instance of ArchiCAD refused to even open. I'll try that again, however. User Error is always a strong possibility with me.
Truth be told, I've gotten used to closing one project and opening another to get things done: Turns out its a lot faster than waiting for that second instance to boot up.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
Csaba Kezer
Hey All,
We have been investigating this issue with the help of some of you. What we managed to find out from the logs you sent to us is the following:
- The issue is that the two ArchiCAD instances cannot connect to each other properly. We couldn't find out just yet why does this happen in some cases, so the source of this issue is still under investigation.
- The memory being used up is the consequence of this bad connection between the two ArchiCAD instances. We will address this by not allowing the high memory usage even if the communication between the two instances is not working fine.
At this point I would like to emphasise that disabling the IPC connection in the registry is not a solution to this, it is only a workaround. Disabling the communication works the following way:
On Windows
In the Registry Editor set the Disable key to 1 in HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD-64\ArchiCAD-64 <your AC version>\IPCConnection\
https://drive.google.com/file/d/0By86zxNvheHtVHJIcXo1ZGZGZ3c/edit?usp=sharing
On OS X
In the ArchiCAD preferences file /Users/username/Library/Preferences/com.graphisoft.AC-64 <your AC version>.plist under IPCConnection set the Disable Boolean key to True
https://drive.google.com/file/d/0By86zxNvheHtWjh0WkozX3F2cnM/edit?usp=sharing
More about Registry Editor or Preferences: http://helpcenter.graphisoft.com/?p=25471
With this switch being disabled the following functionality is not working:
1. Views placed from external files cannot be updated and checked.
2. Selected layouts or drawings on a layout cannot be merged from the Navigator/Organizer. It only works for the entire Layout Book with the Merge command.
3. Open source view command is not working for drawings which are placed from and external view.
To resolve the issue try to delete the IPC Data folder on your machine:
Windows: C:\Users\username\Graphisoft\IPC Data
OS X: /Users/username/Library/Application Support/Graphisoft/IPC Data
Best regards,
Csaba
Csaba KƩzƩr
VP, Global Customer Support
David Collins
ALERT! Systems using NVidia cards: see here!
http://archicad-talk.graphisoft.com/viewtopic.php?p=234494#234494
David Collins
