ā2009-12-01 09:56 AM
ā2009-12-01 10:50 AM
Achille wrote:It might be conflicting with a keyboard shortcut for something else. For example, cmd-alt-d is often the default shortcut for hiding the Dock. Take a look at the Keyboard section in the System Preferences, under the Keyboard Shortcuts tab (see attached image). You can turn these shortcuts off or assign different keystrokes if conflicts arise.
when pressing cmd+option+D, nothing happens.
Any clues, suggestions??
ā2009-12-01 11:00 AM
ā2009-12-01 01:56 PM
Achille wrote:It might be worth double-checking the Input Sources selected in the Language & Text settings in System Preferences.
Thanks, Ralph but no, this is not the case. The problem is not specific to cmd+option+D, but to other key combinations to. And I have un-assigned cmd+option+D as a system shortcut.
ā2009-12-01 02:09 PM
ā2009-12-01 02:38 PM
Achille wrote:Try the fix at the following link:
I have checked the input sources. The problem appears when using the English or US keyboards with Greek as first language in the "Language and Text" settings of the System Preferences.
This is the way I have always used Archicad since today. If I select English as first language, all the Greek text in Archicad isn't displayed properly. In order to use the INT Archicad version and be able to use Greek, i have to set Greek as first language. It worked until 10.5, but now with Snow Leopard there a problem.
ā2009-12-01 03:33 PM
ā2010-03-12 01:12 AM
