Problems installing AC 12 educational
Hallo everyone,
I have a small problem installing AC12 educational version. I had it installed and it worked perfectly. I had to reinstall the Windows on my computer so I saved the installation file a to different computer. After reinstalling the system I saved the file back to my computer. When I try to run the installation file nothing happens. The sign "Program too big to fit in memory" appears in the console window, the console window name says [Inactive Graphisoft-ArchiCAD-12-INT-En].
The same sign appears when I want to install the "ArchiCAD-11-INT-Modeling-Training Guide-Windows" file. ArchiCAD 11 and other AC11 training guides install with no problems.
Any ideas on what the problem is? Any installer missing?
Thanks in advance
3 Replies 3
My operating system is Windows XP home edition, Ram is 2 Gb, and 180 Gb hard drive.
When you reinstalled your OS, did you also reinstall Java? It is required by the ArchiCAD installer I think...
I have Java installed, I guess it's not what the problem is. I downloaded the Modeling Training guide again just now and it installs with no problems. Probably the files got damaged when I was transferring them.
I guess I have to download the AC 12 again. Any advice on how to do it without registering again? Will my final educational version serial number work on newly downloaded ( registered ) AC 12 file?
Regards,
Oleg
