Installation & update
Problems installing AC 12 educational
Hallo everyone,
I have a small problem installing AC12 educational version. I had it installed and it worked perfectly. I had to reinstall the Windows on my computer so I saved the installation file a to different computer. After reinstalling the system I saved the file back to my computer. When I try to run the installation file nothing happens. The sign "Program too big to fit in memory" appears in the console window, the console window name says [Inactive Graphisoft-ArchiCAD-12-INT-En].
The same sign appears when I want to install the "ArchiCAD-11-INT-Modeling-Training Guide-Windows" file. ArchiCAD 11 and other AC11 training guides install with no problems.
Any ideas on what the problem is? Any installer missing?
Thanks in advance
My operating system is Windows XP home edition, Ram is 2 Gb, and 180 Gb hard drive.
When you reinstalled your OS, did you also reinstall Java? It is required by the ArchiCAD installer I think...
I have Java installed, I guess it's not what the problem is. I downloaded the Modeling Training guide again just now and it installs with no problems. Probably the files got damaged when I was transferring them.
I guess I have to download the AC 12 again. Any advice on how to do it without registering again? Will my final educational version serial number work on newly downloaded ( registered ) AC 12 file?
Regards,
Oleg
