Recent file list - where is it so I can fix it?
The recent file list seems to be having difficulty remembering where I was. It may be network related, but to test further I need to clear the list. Does anybody now where it is?
Also, my "Info Bar" is having a little trouble with a composite wall icon - keeps making it magenta. Any ideas on this one would also be appreciated.
iMac 24" dual extreme with 4mb ram, OS 10.4.11, AC 11.
Thanks!
Scott
3 Replies 3
David Maudlin
Scott:
You might look at the Cut Fill Background Pen under Cut Surfaces in the Floor Plan and Section panel of the Wall Settings dialog box. If Apply Structure's Settings is checked, then look at the composite's settings in the Composites... dialog box.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I doubt if this is a GS bug.
[disclaimer/warning:] Not recommended for casual users, of course, and edit with caution:
<User Folder>/Library/Preferences/com.graphisoft.AC.11.0.0 USA v1.plist
is the plist file for the US installation. Double clicking should open the Property List Editor if you have the xcode tools installed. It is an XML file, if you want to edit directly in textedit or by other means.
(For Windows users, this info is in the registry.)
If anybody is interested I accidentally solved it - I think.
I changed my Time Capsule set-up to use "Disk Accounts" with usernames and login passwords. Each computer automatically logs-in (via Keychain) so it is seamless, and now ArchiCAD treats the Time Capsule Disk like any other attached drive. I don't know if it would work if we were to not use accounts and set the Time Capsule Disk to be protected by a Disk Password different that Time Capsule Password (the way I had set-it up and the default set-up). But, I might be trying that in the near future (having some Time Machine problems with Disk Accounts).
Regards,
Scott
