2006-07-27 06:50 AM
2008-04-30 03:28 PM
Karl wrote:One additional thing: you need to have the Arrow Tool active for this to work like this. Other Tools start to create their respective element when you click.
If you do NOT pre-select what you want to drag, but instead just hover your mouse over it until you see a snap cursor - mercedes, check, magnet, etc - THEN, mouse down (do not release) and drag all in one move - you will always drag. Press Ctrl key (Windows) or Opt key (Mac) then to get the + for a copy.
2008-04-30 03:32 PM
Mark wrote:I experienced this same thing on myself.
The problem still happens to me. I maintain the argument if the computer slows, ie drag groups of complex objects then archicad cannot process the right command properly. I can prove this on our computers by trying to exaggerating the problem and dragging a very very complex group of objects, pressing the drag shortcut and then it will 50% of the time revert to drag-a-copy. Note it doesn't happen all the time, it seems to be random, but it will happen eventually.
That aside even working on a very simple drag like a single line it can still happen if i quickly pressing the needed shortcuts.
I now rely on constantly checking if a drag-a-copy was selected instead of drag. Its a constant annoyance.
BTW i don't like dragging by pointing instead of the shortcut as it can sometimes deselect instead, better to be sure everytime and use the shortcut which in the end should work anyway.
2010-09-21 07:27 PM
2010-09-21 11:31 PM
DaveOlufs wrote:Yes, that is how you can do it with the drag option default of the pet palette. The first click is more of a click-and-drag. Then ctrl key for one copy or alt+ctrl for multiple copies. These are toggles of course so hitting them multiple times changes things.
Couldn't one just click to select and start moving the object? Then while moving, hit the OPTION key to copy... a standard on Macs and probably on PCs.
2010-09-22 01:00 AM
2010-09-22 04:07 AM
Karl wrote:It's the CTRL key on windows for a copy.
At that point, tapping the Opt key (Alt on Windows) will show the "+" sign next to your cursor to indicate that you are dragging a copy.
2010-09-22 05:58 PM
This is not the case if you select and drag in one motion.Not knowing AC well enough to understand why one can't select and drag in one motion is NOT a default action. I hate having to select an object THEN hit a button to move/drag it. Yes I now know there is a button in the pet palette that allows select/drag/move in 1-move but it requires another mouse click. Moving something has to be one of the most common actions short of view adjustments and anything to speed or ease the process is my wish.
The copy will stay active if you select before or after letting go of the mouse button.
2022-04-12 01:39 PM
I'm having the same problem 16 years later with Archicad 25. Nice coding, I guess.
