!Restored: post-hotfix buggy behavior paranoia
-With drawing items/objects/stuff selected, parameters edited in Info Box affect selection, but then Info Box loses info for still-selected item(s), showing either blank or default settings. Must re-select item to show proper info in box for further editing/verification. This is terribly annoying.
-3D window frequently shows nothing... dunno how I've switched back/forth from nothing showing to everything showing. Is curious. Did not notice this with previous build or v11.
-I'm getting a far more frequent appearance of the rainbow wheel while engaging in basic operations (drag, rotate, copy/paste, extend, etc).
-Ramps are locked into some sort of Riser ratio that doesn't allow for defining the ramp total height outside said ratio. Defined/locked parameters only related to length/width of ramp, and the riser/tread settings are grey and un-editable. But then, I've never used ramps before, and this may just be a funky tool issue (like so many others.....)
14 Replies 14
vfrontiers
Nothing interacting with color dialog.. Again, it works the FIRST time it's called up, but never after that. I originally thought the the palette was there, just hidden, but no amount of moving screens around will show the color picker box.
I have to restart ArchiCAD to get the box back.
Only one guy in the firm is on the new build. I can open his file and use color picker flawlessly on the past build.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
So ,we have to wait until graphisoft , made a hotfix , to solve this problem ? plk when this happen . thanks
Again, I do not have the problem on my Mac ... so if the bug still exists, somehow you guys have to create a 100% reproducible condition for Graphisoft for them to know how to reproduce the bug...
3djunior - what machine are you using? (Put it in your signature.)
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Hi Karl , yes i forgot to mention , iam using an IMAC G5 , 2.5 gb RAM , and only to add at the coment by vfrontiers , i remember have working on the color dialog box , in ligthworks just before i noticed the menu display problems , so this is closely realtioned with the wrong functionality ?
jbArch
Jocelyn & Others:
Did you ever get things working normally? I'm still having this problem, and not ready to fire up AC13 yet.
I have found that this problem is more frequent when I use a file that was started in an earlier version.
But today I have two good files that were started with the AC12 template, both working fine. But if I merge the files? Then the same info-box problem occurs in the 3D window (no problem in 2D).
JB
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
