‎2021-01-07 11:45 AM
‎2021-01-08 10:46 AM
‎2021-01-08 01:28 PM
‎2021-03-03 09:40 PM
‎2021-03-08 02:42 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-06-20 04:10 PM
‎2021-06-21 11:31 AM
Minh Nguyen
GRAPHISOFT
‎2021-09-10 09:59 PM
Hello everyone ! Turning off the ELEMENTS INFO Pallete will increase very much Archicad Performance. All functions that envolve selecting ou deselecting elements are related to this palete. Graphisoft needs to verify this issue. I think is an Elements Counting problem.
‎2021-09-14 11:36 AM
Hi Marco,
Thank you very much for sharing the issue!
The intention of this palette is to list the detailed information of a/some certain element. If we have it enable while selecting a large number of elements, it will take some time to list all of the parameters for every single element. Due to this, slowness will happen when the list gets big. I suggest turning off this palette and only call it when needed.
I'm very sorry for the inconvenience, and thank you very much for your understanding! Please let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
‎2022-02-03 08:33 PM
Will this ever be fixed? I work with detailed projets and every second operation involves info palette, It is also taking time for palette to turn on and off. Like a couple of seconds. So, turnin palette of is not solving the problem. A pause of 2 seconds between operation makes me losing focus and makes me very nervous. I hope this issue will be fixed in 26 version.
