Starting the wibu on windows..?
I became familiar with starting the wibu key in the mac, thanks again guys. How do I start the wibu key when my environment is windows pc (winXP) ??? I've already installed the latest wibu driver for windows from graphisoft..
3 Replies 3
Djordje
Install without the key. Reboot. Insert the key. Choose automatic installation. That's it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje! I just want to make sure though, when you mentioned "Install without the key."... did you mean install "ArchiCAD" without the key? Thanks again.
Djordje
Yep. If the driver is not installed previous to the key being inserted, XP will look for nonexistent drivers. So, install ArchiCAD - and the drivers - first, then reboot (just in case) and insert the key.
Djordje
HP Omen
