rlrueter
Text and Dimension text disappears.
I've been an archicad user for a long time. (Since V3.14). I don't use it a lot any more so I have not upgraded recently.
I'm using V10 on a mac. OS10.7.3
Here is the problem.
Text disappears from text boxes and dimension strings.
It will reappear sometimes and then disappear again when I save.
I've tried to bring it all to the front in the display order and it does not help.
I don't think it is directly related to lyon because it started before I changed.
If you have a fix or work around please let me know.
email is rlrueter@mac.com
I just figured out something. When I select the text on a dim. string all the dim. text and all the text in boxes becomes visible then disappears again when de-selected.
0 Replies 0
